Precision
- 125
- 3
- Apr 11, 2005
Bloomington,
Illinois
Like the title says. I've been looking into a DEI CO2 set up and just wondered if they were worth the money.
avw0516 said:I don't have one, but I do agree they are definately cool. No pun intended.![]()
Seriously though they are the same concept as the N-tercooler kits and that stuff. I am sure it would work fairly well as co2 is some cold stuff (have had some paintball experience). I am curious to see how much some people have benefitted off it though because it is way cheaper than nitrous.
avw0516 said:Really? Thats kind of odd, but thats probably why nitrous is so much more expensive.
VelocitàPaola said:I think he was talking about intercooler sprayers in general. I've heard gains from nitrous sprayers are negligible from numerous people running them. In theory, the cooling effect of evaporating nitrous oxide should be greater since its melting point is about 40 degrees (Celsius) lower. The concept of these systems is good, it just isn't very functional.
Precision said:I should have no problem getting in the 10's.....I hope, I agree a alky kit would be a better all around buy. Do you recomend a paticular set up?
Turbocharged said:If you vehicle profile is up to date and your car isnt stripped to hell, then you will have to be the worlds best driver to get into the 10's with some high octane fuel.
oddrob said:On two different points, I usually see a 15-30whp gain using the intercooler sprayers. On the alcohol injection, with the set-up we use it runs srtaight denatured alcohol, and I've seen gains of up to 120awhp.
riginally Posted by oddrob
91-gsx said:120awhp, that is freakin crazy.
later
You should give 100% distilled water. Here are some latent heats of vaporization:
Gasoline: ~140 Btu/lb
Ethanol: 361 Btu/lb
Water: 970 Btu/lb
The idea behind water injection is to replace excess/nonstoichiometric gasoline with something that has a better cooling capacity (in this case water). When I say "replace", I mean leaning out you A/F ratio. Many people get caught up in trying to add something with a supposed "high octane". Replacing a little gasoline with ethanol will not significantly change the octane rating of the intake charge. Adding a 50/50 mixture will actually LOWER the octane (although its only on the order of a 0.1 octane change); although you will end up with a latent heat of 665 btu/lb, water is still a better choice.
The idea is to replace the gasoline with something that will quench combustion temperatures. Water is almost 3 times better at doing this compared to ethanol or methanol.
oddrob said:"Since greater compression ratios in an engine mean increased power per stroke and greater efficiency, the ability of a fuel to resist premature detonation is a desirable quality. The "octane" numbers assigned to fuels are based on the pure hydrocarbon, octane, which is considered to be 100. At the other end of the scale, n-heptane is considered to have an octane rating of zero. The octane number of an unknown fuel is based on the percentage volume of a mixture of octane and n-heptane that matches it in preignition characteristics. In practice, these tests are conducted in a special test engine with variable compression. As noted in Figure 2-2, alcohols have a relatively high anti-knock or octane rating. As noted in Figure 2-3, alcohols have the ability to raise considerably the octane ratings of gasolines with which they are mixed. "
This is right out of the book....
91-gsx said:dont be, this stuff is always fun to talk about. now i have another question for you on top of the question that i already asked you. so you think if i use water instead of alcohol, i wil be able to run more boost and timing and a leaner mixture? this is getting interesting.
later
