1fstgvr4
- Sep 10, 2002
Fishers,
Indiana
Well after a long time of running like poo my car running strong again (major boost leaks) and now it's time to hook up my evc... though I'm not 100% & sure I don't want to hook this up and screw anything up. I was gonna run port #1 to the plenum and port #3 to w.g. both of which are quite obvious but I am not sure where I should run #2. Instructions state not to hook it up after the throttle body soo if I run it into the bov, where the mbc is hooked to, I could get bad readings right?
There is a nipple on my ic pipe directly after the turbo, should I tie in there? And if so what do I do with th line to the bov?
Thanks in advance for your time and help!
