focusedrage
- 1,053
- Aug 3, 2002
Laytonsville,
Maryland
I look at it this way:
Raise the boost one will need a better feul control and delivery system. but on the other hand a set of higher compression pistons will compress the boost more once it is in the cylander, valves closed. So i imagine one coudl get some easy hp by changign to hight compression pistons vs all sorts of boost related troubles. Is this true? one miht need a higher octance to run that compression but i would think it woudl work.
Right now i run 13 PSI at the stock compression, what kind of increses woudl i expect in hp if i swithc to a higher compression ratio?
