Nos~4G63
- 340
- 2
- Jun 2, 2002
Davie,
Florida
I attemted to start my project car friday and after 30 minutes or so of charging the battery and cranking without the car starting I decided to do a compression check. There is no compression in any of the cylinders. I figured the timing was fine because I started the car a few months ago and it was idling fine. I just turned it off to fix an oil leak.
Could this mean the timing is off and just needs to be readjusted or set? Or does this mean there is bent valves? I thought maybe the timing belt jumped a tooth and needs to be re-set but my friend said if it jumped a tooth then it bent valves.
