2G pistons on Eagle rods
What do you have to do? Eagle rods are made for floating pistons and the stock 2G pistons are pressed wrist pin type. The dealer put in a new block and I want to change out the stock rods while the engine is still new. I want to do this because my goal for my car is about 400whp and I don't trust the stock rods.
I know a guy that put 2G pistons on Pauter rods. You should be able to do it with out a problem.
before i did my buildup i tried doing that, the problem is that the 2g piston pins are 2 things:
1.) not floating wrist pin, which is what the eagle rods are setup for
2.) slightly larger than the hole (I.D.) of the eagle rods.
the eagle rods have a bushing in the piston pin end for the floating wrist pin. You cant machine down the piston pin because the hole in the piston would be too big then, and i certainly woulndt want to remove the bushing and put a bigger pin in, because youd have to not only bore the rod end out a bit but also the piston bore for the pin. Too risky for me, i didnt want to mess with the structural integrity of the rotating internals. So i went out and got wiseco pistons, good price, and they are great, i have like 3000 miles on my motor so far and no problems.
PM me if you have any more questions
Albert
