RavenX
- 659
- 5
- Sep 23, 2002
Daytona Beach,
Florida
I was wondering for anyone that has the bullseye to4b vtrim could you tell me what your setup is and around what rpm the turbo is spooling at. I asked this because i just recently got this turbo and i am hitting 15psi by 4,800rpm. I have a built 1g head and intake manifold with fp2cams. I already talked to dave and he suggested to check for leaks first and then tighten the wastegate spring. He also told me that this turbo is supposed to see 15-20psi by 3,500rpm. Did any of you tighten the spring as well and if so how much? Let me know thanks
, I adjusted the actuator a little bit but did nothing my boost wont go up or go down so I dunno what im gonna do?! probably go external with the gate and get a brand new mbc.
...If after the boost leaks it does the same thing i will go visit you dave at your shop i'll keep in touch via email
