20g on 2g
[email protected]
Oct 13, 2002
Niles, Michigan
I was thinking about going with a 20g on a 2g. My question will the stock internels hold up to the challenge. With good tuning.
Thanks
Ryan
I run the HRC S20G - Ported on Stock internals
Dyno'd
322whp - 22psi on 92 Oct
363whp - 24psi on C-16 Race Gas
My Supporting Mod list:
Walboro - 255HF Fuel Pump
RC 550 Inj
SAFC
HRC I/C Piping
Blitz BOV
Greddy Large FMIC
ARP Head Studs
HKS 264/272 Cams
Magnacore 8.5mm Spark plug wires
NGK spark Plugs
Injen Intake w/K&N
Ported Exhaust Manifold
3" 02 housing
3" modified Tanabe
3" Thermal R&D Exhaust
-Brian
if you plan on going over 20psi regularly invest in the ARP Head Studs, i havent done it myself, but if you excede about 24lb you'll have fun with head gaskets needing replacement.
If your 20g is a TDO5 I doubt the 18 will be any better at all. And if its a true Greddy 18g the exhaust housing is even a bit larger than the 7cm you likely have on the 20g. If its a TDO6 20g then lag should get better. Otherwise I wouldnt bother. My TDO6 50 trim is fully spooled (25 psi) by 3500, and above that boost comes up very fast. I drive 600-1000 miles per week and have no complaints :D But it is a matter of personal taste...
