norice4me
- 298
- Oct 10, 2003
sewaren,
New Jersey
ok so today i got the money from the person keying my car in the mall parkinglot i got 700 dollers to spend what should i spend i on this is what i have done so far. i just ordered injectors 680's.so i have 450 to spend
Exhaust
Buschur Racing 2.5" downpipe
2.5" Test pipe
Dynomax 2.5" cat back
Ported '95 Exhaust Manifold
Ported O2 housing
16G/TD05H with ported 7cm2 turbo housing
Motor
Unorthodox underdrive pulley
95 pistons
big rods
fluidyline radiator
high cooling fan
balnce shaft revmovel kit
Electronics
Blaha MAS
APEXi Super afc
APEXi turbo timer
hks evc boost controller
reprogrammed ecu
Intake
K&N Filter
busher 2.5" upper intercooler pipe
busher 2" lower intercooler pipe
busher front mount intercooler
Fuel System
Walbro 255HP Fuel Pump
510cc injectors waiting on 680s
DriveTrain & Suspension
ACT 2600lb Xtreme Clutch
'94 Tranmission
Dunlop SP8000 Tire (225/50/16)
Konig rims
Eibach springs
Brakes
Big brake upgrade
front Cross Drilled rotors
back slotted
Braided brake hose's
KYB GR2 struts
Exhaust
2.5" Test pipe
Ported O2 housing
Motor
95 pistons
big rods
fluidyline radiator
high cooling fan
Electronics
Blaha MAS
APEXi Super afc
APEXi turbo timer
reprogrammed ecu
Intake
K&N Filter
Fuel System
'94 Tranmission
Konig rims
Eibach springs
Brakes
Big brake upgrade
back slotted
KYB GR2 struts
sorry forgot that.with the fpr only reson i dident order it is cause of the waits what is the best place to get it from thanx.
there never big enough.
