hellotbone
- 1,032
- 22
- Apr 15, 2003
Anyone got any good tips to try and fix the 2 small oil leaks in my 6bolt motor? I took the pan off and re sealed it because I thought it was leaking but it seems to be coming from higher up the block and running down. Both sides leak slightly but enough to leave a drop or 2 of oil in the driveway after each drive. Anyone had similar leaks and found an additive or something to stop it?
