clipped turbo
InjenTalon96
242
Oct 12, 2003
Plainville, Connecticut
can anyone show me a picture that shows what a turbo looks when its been clipped....
thanks alot!!!!!
Clipping the exhaust wheel allows you to flow more exhaust gas at higher RPM's resulting in more top end horsepower.
mine has a clipped compresser housing wheel, what would i get out of that....i notice my b16g spools up around 2200RPM, would that help at all????
CanadianTSi said:
No it makes spool up worse because they is less blade for the exhaust gas to push.
well in my situation im clipped at the compresser wheel, so what advantages would i get out of that????
None. Why reduce your flow rate? Sounds like a fu(ked up turbo at best. How did you get a "clipped compressor wheel"?
clipping the xhaust wheel lessens back pressure, when you go to 3in exhaust on a car you get more tg and hp but your low end is a little less. you flow alot better up top, but thats it.
