1fast97gsx
- 4,517
- 17
- Jul 6, 2003
Orland Park,
Illinois
I know this is a controversial issue of whether to use it or not but I choose to use it this time. My friend gave me some but it doesn't have any instructions marked. I'm assuming I put it on the bearing surface ( in the groove? ) then torque everything down to spec. Then unbolt it and compare the size of the plastiguage to the markings on the pack? What are the correct bearing clearances for a 2g gsx? What if I'm off ... I have to have it machined and go with oversized bearings? Last time I did a rebuild I used standard sized stuff and had no issues that I know of and I didn't plastiguage it. Now that I'm building my "strong" engine I want to make sure everything is PERFECT.
