CatchMe
- 127
- Jul 22, 2003
Kingston,
Massachusetts
I've done alot of searching and I can't find a solid answer to my question. I'm going to be installing a PTE SCM3231E (54 trim compressor/ 76 trim turbine - rated at 480max hp). I'll be running this turbo close to its max. efficancy range (hopefully 20psi on pump 93oct.) What do you think a walbro 190 (base FP ?) would flow with PTE 680cc injectors on around 20psi? Would it be enough rewired @ 14 volts? Or should I get a 255lph FP? I will be using a aeromotive FPR BTW. Thanks in advance -Zach
thats tuned running a 10 - 10.5:1 AFR via DSMlink. I think i'll be getting a 255lph to be safe. My 190lph is up for sale
. -Zach
