compression leak down
bjones18
299
33
Jun 3, 2004
canton, Michigan
I just did a compression leak down test on my 4G63:
1. 4% - slight hissing from crankcase
2. 6% - same
3. 12% - crankcase and exaust hissing
4. 4% - crankcase
Is this much variation normal? (the 12% number) or is something wrong with #3?
Bob
the exhaust is from your valve no seating properly and will cause compression issues ad lack of power concern. hissing in the crank case is from blowby what year? Yes there is a problem with the rings or cylinder wall.
Andrew
I dont know the spec of the top of my head(Im at school) but Id be willing to bet that the 12% is from a bad exhaust valve(s) in cylinder 3. Usually if something happens to a ring the same thing will happend to the others as one cylinder isnt filtered from the others same exposure i.e. you run without a filter dirt will get in each cylinder not JUST cylinder 3.
Andrew
