JimmyJ
- 70
- Feb 19, 2003
hey whats up, i have a 95 talon tsi with a injen intake, hks cat back, 550's, 255 fuel pump, and a evo 111 16g with an AFC11. I have a manual boost controller also. I cant seem to get above 10 pounds of boost and when i hit the gas the car like stutters and jerks and at high rpm's it is just not smooth. It hesitates and and seems like im not getting any fuel or whatever it is. its pretty bad and my car is running like crap. If you know why it is doing this let me know
thanks
thanks
other than that if yuor running the stock SMIC check your piping or take off the heat shield and check for exhaust leaks that would cause your car to run like crap as well if you have a big enough boost leak
