evo III oil and coolant line help?
snappy51980
Mar 29, 2004
west salem, Ohio
Im using the evo III on a non dsm I'm not familiar with the turbos oil and coolant line locations. On the turbo there are 3 differnt locations where you run the lines to and i was just wondering whic is which?
Thanks Adam
should be four holes on the center section. two on the sides are water lines and top and bottom holes are for the oil
Thanks for the reply. For the oil lines is the one on the bottom for the supply or the return?
Thanks Adam
