Super AFC settings for 1g
Black90GSX
Apr 13, 2002
Need some help! I'll be installing my 660cc injectors in my 90GSX this weekend. I need to know if someone has a simular setup, I know that all cars are different but this should put me in the ballpark at least. I am using the Super AFC. Also how well do cars idle with injectors this big? Thanks in advance...
All cars have pretty unique AFC settings because of base fuel pressure, injector size, state of tune and MAS.
How hacked is your MAS? What is your base fuel pressure? What fuel pump are u using? Without all these info, it's difficult you give you a ball park. Generally, you can use this formula ((450/660)-1)*100
I'm using the upgraded unit that RRE sells as far as my fuel pump. I'm not sure what my fuel pressure is. I'm still using the 1g MAS with only the lower honeycomb and silencer removed. You lost me with the formula. Can you explain it to me?
