Intercooler install help - what can I remove? PIC attached
1990CherryTSI
Banned Member
62
Jan 24, 2004
Austin, Texas
It's a customer intercooler more or less (the two ATI procharger's I bought welded together) so there is no "install document" that came with it
1. Is that metal tube necessary? It looks like it runs the power steering? Can you just route that line that comes through the firewall up to the pump instead of having it wrap in front of the radiator?
2. How necessary is that support there? I know it holds a clip hole for that front bracket between the lights but I'm not to concerned with it clipping in there so can I remove it or will it cause some structural integrity issues?
3. What is that? I have a manual and can't figure it out. I'm not sure what it runs to.
4. Part of 1., can this just be routed back up to the pump?
What is that small little "mini radiator" in front of the AC compressor side of the radiator? I didn't number it but it's like a mini radiator.
Did you guys mainly just cut into the bumper/support and fit it in front of all that? Or did you guys remove all the stuff I'm looking to remove? Thanks for all the help!!!:thumb: :thumb:
Yes it's part of the power steeting system (a cooler I believe) and you can not remove it You can, however, move it around and extend the lines to move it farther away or around. I put it behind the bracket your calling #2.
I would not remove it, you can use it to hold back the power steering lines as I suggested above. It will not be in the way of the FMIC at all.
It looks to me like an aftermarket oil cooler and those are the lines
It is routed back up to the pump now. Just tuck it behind the bracket.
Read #3 looks like an oil cooler and those are the lines
I cut the bottom of the bumper out so the cooler would slide up inside of it and be flush with the flat part at the front. You still have the bumper support and make lots of room for the cooler. You can see my power steering lines moved close to the fram of the car and I put them behind that support. I just unscrewed the support and tucked them back up there and zip tied em up.
it looks like it's been there since the car was made. The holes for it etc are all lined up and brackets all look made to be there. I guess if it is an oil cooler than it's a good thing so I'll let it hang there. So the best bet is to leave everything, and just cut the bumper so it fits forward, except the power steering cooling line and just throw that back behind the front support piece. Thanks!
Yep, there is lots of room in the front of a DSM for a large intercooler. Once you get the bumper off and look at the support you will see what I mean. Just cut the under side so you can slide a cooler up in there, and presto you now have 30"L x 12"H x 4"D to work with.:thumb: Just for reference my cooler is 28 x 8 x 3.5 and it fits snug-as-a-bug-in-a-rug.
That car is a 1990. That is the factory air to oil cooler that EVERY SINGLE 1990 turbo DSM came with.
You can't remove that support, you also need it for the hood latch.
You can get rid of the power steering cooler, but I wouldn't suggest it.
you can remove the support and the hood latch will still work.
