Frankenstein
BlackViper
376
Sep 3, 2002
Goose Creek, South Carolina
If I did everything up to lvl 4 on www.extrememotorsports.com could I put in a Level 5 Frankenstein in my Talon? or is it only for on the track?
Cause thats the highest one I see on www.extrememotorsports.com I know it will take awhile to get to lvl 4 on there but I just wanted to see what to get for the big turbo upgrade so I can save some money for that when I get there.
BlackViper
In order to utilize a frank 5 or any turbo of its relative size you will NEED to go to extremes stage 7. I suggest you read alot and figure out what your goals are before you even think about a "killer" turbo upgrade.
I plan on going to lvl 8 which is the last one but was thinking that the major upgrade was the turbo. Since the Turbo was lvl 5 I just figured the lvl's beyond that wouldn't matter as much as the ones before. But I guess I'll do each step by itself instead of getting an overall plan worked out or just get a rough idea of what I need. Thanks for the info.
BlackViper
Buying a big turbo is just like going out and buying the biggest baddest headunit for your car you can find. By itself...yeah you have the baddest head unit in the land but it sounds like sh!t. The more you support your new headunit with stuff like... subs,amps, good speakers,etc the better it sounds and you can start to really crank it up. Its the same for the turbo... once you support it properly with the right mods it will run great and make alot of power, otherwise it will run like sh!t.
