Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > General > Tech Article Archives > Articles: Exterior/Interior
Add to this Article
LinkBack Thread Tools
Old 03-31-2007, 05:16 AM   #1 (permalink)
Proven Member
tom04841's Avatar
Region: New England
Classifieds Rating: (0)
Reputation: tom04841 is pretty helpful and trustworthy
97-01 Impreza bumper on a 1GA
In the pics above, you will see circled in red the places that need to be trimmed on the back side of the bumper to clear the bumper support. Also is the large opening in front. There is normally a bar that goes across that opening. (see below) I cut that out to open it up for better airflow to the IC and radiator. It does need to be trimmed back to clear the bumper support as well. Just go slow. Trim a little and re-test fit, etc, until you are happy.
I didn't drill new holes on the bumper cover. I drilled them in the bumper support. I used sheet metal screws with washers under them to secure the bumper. The only stock hole in the bumper support i used is the one in the middle. Now when you go to attach the bumper to the fenders, if your stock bolts didn't break taking them out, you are in good shape. The Impreza bumper has oblong holes for mounting, and will work with the stock bolt. If your bolts broke, grab your drill, and go to town drilling out the broken bolt. You can retap it after its out, or just go with a larger bit so you can use a bolt and nut.
Both my stock bolts broke, so i found it a good time to stick on my Z3 fenders. I lined up the bumper, drilled a hole in the fender and bolted it up.
Here are some side pics of the "finished" install.
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Add to this Article
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are Off
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.11104393 seconds (71.90% PHP - 28.10% MySQL) with 9 queries
