'96_Talon_TSi
- 882
- 1
- Sep 24, 2003
West Bloomfield/K-zoo,
Michigan
I know.. you guys see the title "sub box" and think OH SHITE, another one!
Well, i know what im doing, just need to check up on a couple things.
I already have a sub box, but i would like to make the inside volume a little larger, so i can get those long deep notes. I would like to keep the box pretty light, so i'd like ot make it out of lightweight wood.
1)What would the best lightweight wood for a sub box be? (please keep in mind its going to be a frame for the fiberglass)
Now, im also going ot making it a fiberglass enclosure, which is why i'd like to keep the box light, as it will be a permanent installation and i wont take it out when im at the track.
2)What kind of fiberglass would you guys recommend for doing this? Would i be better off using a mat for the initial installation (pulling it over the wooden box) or should i use a polyester or similar fabric?
3) After the initial layer of mat, polyester, or whatever i'm using.. would you guys recommend using a woven sheet, or more mat?
BTW: I have 2x 10" MTX_Audio Thunder 6000 subs.
THanks guys.
THanks guys.
