Burrito06
- 73
- Jan 9, 2003
Sacramento,
California
One of my Gauge bulbs burned out so I replaced it. The thing that happened was that when I went to reinstall the gauges I guess I accidentally pushed the fuel pin up. You know the pin where it show you how much gas you have left. I was wondering if it will go back down to where it was before I replaced the bulb. I was 3/4 of a tank left and now the pin is way past the Full letter. I was wondering how would I fix this. Should I unplug the battery and maybe it will go down that way or do I have to fix it manually.
indeed, after i did my indiglo needle project it got a little goofy so i had to do it a couple times, now if you remove the needle you place it incorrectly you have to remove and place it properly.
