rice_rocket
- 107
- 3
- Apr 20, 2002
Natick,
Massachusetts
I have a problem with my 2g install of HID's. I have a phillips complete kit, for the 9006 retrofit and a D2R bulb. Standard Phillips basically.
Anyways I have a problem with my passenger side light/ballast not lighting up! The weird problem starts here.... both the setups bulbs, ballasts etc work perfectly fine on the driver's side, yet on the passenger side it won't light up at all!
Now what's wrong with that? I plug in the stock 9006 bulbs and it lights up, so that's fine, but why doesn't it fire up the ballast?
Now I thought.. heck I'll just leave it like that, go for a 30 min drive or so. After about 10-15 mins my lights go out, the brake light, battery light, and alternator light goes on. Crap I thought I melted something. Went back home, found out the headlight 40A fuse blew, got a new one and everything is back to the same problem.. the passenger side light doesn't go on.
Can someone tell me what could be the problem here? Any weird possibility that the passenger side doesn't produce enough current to light the ballast for some odd reason?
I would assume there is no point in trying another HID kit (which I don't have handy).. and I don't really want to return this one since when I swap sides both sets work.
Thanks!
Thanks!
