brcewane
- 222
- Nov 8, 2002
I'm new to wiring sound systems in cars but would like to do the work myself.
I want to keep my stock head unit but I do want to add some punch to my sound system... I am wanting to do a setup for show and for when I don't need my trunk. I will be building my own custom enclosure/fiberglass work in the trunk and want to run 2x10" subs in the back and also put my XBox in there for show with 1 a 7.2" LCD panel for the XBox. This stuff is all going to be removable.
So from my little knowledge of how this stuff works this is what I am wondering if I can do:
1) Keep stock head unit and Amp for existing 6 speakers (rear 6x9's, front 6.5's and dash tweaters)
2) Run a second 2 channel Amp in the trunk for my 2 subs
3) Somehow connect the stock Amp to the second amp in trunk to power subs when unit is connected and turned on
4) Connect XBox into one of these Amps so that the sound goes through all speakers
Am I on the right track with this and will it all work??
Any help is appreciated.
Tim
Tim
symbol in the back that will be red when the rest is color matched green... I have started on the frame.. I will keep you all posted on the progress...
