Black95TSIawd
- 2,620
- 411
- Jan 28, 2003
Dirty,
New Jersey
my passenger headlight is pretty hazzy. The driver side looks new. The front of the car looks ugly because of the passenger headlight.
Is there a way i can get it to clear up without having to replace the headlight?
Just get some of that, dilute it a little bit with water. Take your headlight off, remove all the bulbs and whatnot, pour it on in there, swirl it around a bit, and it should clear up. After you do this and pour all the water out, you might want to leave it sit for a day out int he sun to get the rest of the water to evaporate so you don't get condensation in the light. Other products you can try are CLR, and sometimes even vinegar diluted with water will even work.
