90 Laser Headlight Cleaning
Do you mean the headlight, or the clear lens next to the turn signal? Your headlights are sealed beams, unless someone's modified them (you should if they haven't).
Couple of screws that hold it on should be visible. Use Mother's Mag Polish to clean off the yellow.
Actually I had just cleaned mine on a 93 Eclipse and used $1.97 Turtle Wax Polish. Shocked me how well it worked. As for the leaves if your head lights are like mine with the cap on the back maybe someone had it open in a yard for awhile and they blew in there???
Mod them in what way?
