Brian
- 154
- Mar 26, 2002
toledo,
Ohio
Alright I replaced my indiglo's with reverse indiglo gauges and I plugged all the connectors into eachother and then I used the ground and power wires that were already there with the other gauges. I put the cluster back in and they dont light up, everything else works such as stock lighting and stuff but the gauges dont. All I can think of is the power or ground wire is loose. Do the connectors that connect to the control box have to be in any order cuz the shitty directions say nothing about that. Let me know what you think.
