$5 DSM Makeover
Boost95
403
Oct 21, 2004
Wilkes Barre, Pennsylvania
I got bored this weekend so I figured I would put use to the supplies in the garage.:rocks:
TailLights look much darker in the pic.
Damn, your headlights look brand new. How'd you go about cleaning them? I'd like mine to look like that...
looks nice. damn, that UICP looks like it should hit on the hood. And is your intercooler crooked or is that just the way the bumper sits?
I just wet sanded them with 1000 and then buffed them with a rubbing compound. And then just used a polish then threw a coat of wax on it. I put my clear corners on a long time ago and took them right back off because they made my headlights look even worse. Now they all match up nice.
DSMcamaro- check out my other listing for DOES MY UICP LOOK TOO HIGH and if my bumper is "crocked" :toobad:
But yea, it is a little "crocked" now that you mention it. This is the 1st time in a while I put some time into the car to notice. The UICP is too high too :boring:
Its a quick easy way to clean your car up . :thumb:
-Mike
Nice, but I have to ask, whats the blue? I seen it before but never thought of asking.
The blue is from the bulb in the headlight houseing, its just reflecting off it.
They sure did clean up nicely, good job.
Wow, I thought you opened up the headlights and cleaned inside them also, they look so good!
Looks good, although every time I do that to my car it tends to last about a month or two before they're all fogged over again. Did you just tint the taillights darker?
If they fog up again I wont need to worry about wet sanding them. I will just use a polish on them whenever I wash the car :thumb: Yea, I just used that Translucent Light tint . I just put one light coat on them. They look much darker in the pic. I will post one in the daylight when I get a chance.
You should polish the IC piping. It would make a big difference cosmetic wise. Sand em', polish, then clear coat.
Another $5 makeover:
