D_Eclipse9916
- 1,430
- 16
- Mar 4, 2004
Vienna,
Virginia
Alright so I got the components and everything inside my door so that you cannot tell it did no come factory that way. Now I want to put the amplifier in and I have a question. I am installing the amplifier in the stock amplifer position (under the passenger seat) and I was wondering if I just connected the input on the crossover to the stock wiring, I could go off the speaker wires that went to the amplifer and instead of them going to the head unit I could basically connect the wires from the harnes on the stock amplifer harnes, to my aftermarket amp and just run it like that. It would be much better and I wouldnt have to do all this work to make sure no wiring and the car looked stock running the wires from the speakers to the amp. I was hoping it would work like this
HEAD UNIT---RCA--Amplifier
Crossover---stock speaker wiring goes to the harness from stock amplifer????----Amplifier
I might just go outside and take a picture...
