sc2_ct
- 151
- 4
- Apr 2, 2004
Meriden,
Connecticut
Well, I asked a similar question before but didn't quite get the information that I was looking for. I have my entire interior torn apart with the exception of the hatch area and some minor trim pieces on the inside, and am wondering which way to go with the dashboard. I was wondering if it is possible to remove just the padded portion of the dash without pulling the entire dash assembly out of the vehicle? I can see the bolts where the kneepad/glove box are and was wondering if after I pull the rest of the insturment console trim if I can just pull out the padded part? I'd rather not have to go through and disconnect all of my cables, but I'd definately like to fiberglass a replacement for that one padded piece.
I'll probably have the rest of it apart in a couple of days but figured I'd ask in any case since it would definately help with my planning to know one way or the other before I start tearing into it.
For reference, here's the original thread I posted on this subject:
http://www.dsmtuners.com/forums/showthread.php?t=171824
, there's lots of work left to do, but having the pieces apart will make things go a lot faster. I've got the whole dash disassembled in the basement and am just starting to mask the frame, and the padding is getting glued back in place (another couple hours and the glue should set). Next comes a mold and then a casting of of the padded portion, then strip off all the vinyl/foam and bond the casting to the metal and re-shaping. Phase 1 will be a mostly stock-looking replacement, but since I'll have all the molds at that point, I can start on phase 2 which is a total re-design of the entire assembly with new doors, quarter panels and hatch area to match.
