TracOwner
- 291
- 5
- Mar 27, 2005
Denver,
Colorado
which size and width suits the 2gen dsms best both for performance and appearance?
jtmcinder said:Tire and Wheel Size
A lot of people seem to want to wedge wide tires onto skinny wheels. A lot of people seem to want to run 18" or 19" wheels when they don't have the huge brakes that would make this necessary. It needs to be recognized that many cosmetic mods will actually lower performance. For a street-driven 2G, there really isn't that much of a question, in my mind. If you want the speedo to be accurate: 235/45/17 on a 17x8 with an offset around +42mm. If you want the car to perform a bit better: 245/40/17 on a 17x8 or 17x8.5 with an offset around +40mm. If you're really serious and run super-high springs rates for racing, but don't have huge brakes, then your streets can be 245/45/16 on a 16x8 or 16x8.5, which allows you to use bigger sidewalls to absorb more of the road
