Utilizing the Factory Amp on a 2g
Rollout
Dec 10, 2003
Mahomet, Illinois
I purchased a din to rca adaptor from www.installer.com in order to utilize the factory in-car amp and also get feedback from the factory front tweeters, but I can't figure out what im doing wrong when i hook it up... Here's the unit (top of the page) http://www.installer.com/acc/index.html
Here's the logic i have used, if anyone has done this before, let me know what im doing wrong...
First off, i figure that all eclipses came wired for an amp and for no amp. the ones without an amp(GS, RS, i assume) obviously only require 4 speaker hook ups (the ones that plug into the back of the wiring harness), the cars with factory (GST, GSX) amps require the use of 6 speaker hook ups.. These wires plug into the factory amp on a wiring harness.. Unfortunately the amp has a din connector, so this is why i bought the adaptor to convert to RCA. The adaptor has a a din connector AND a blue wire on one end, and a front and rear output (not labeled which is which). I have no clue what the blue wire is, i assume it's remote, but not positive, and im not sure which is rear and which is front. I have tried connecting them both ways and i have tried hooking the blue wire to the remote also. None of this worked. This product came with no instructions and the packaging says it was made by "Peripheral Interface Components". Also, I'm assuming having both the wires for the speakers which plug into the back of the cd player (wiring harness) and speaker wires that plug into the factory amp, plugged in at the same time could fry the amp... For a time, they were both hooked up, so maybe thats whats wrong..
Hopefully I can get some help on this, The only other thing i can think to do is bypass the amp all together and put in new component speakers... What have you guys done?
Hook it up as you see in my crude MS Paint diagram :D
Do NOT hook up any of the speaker wires to the wiring harness, only use the Power, Ground, and Memory wire.
I use mine as a paper weight.
When I installed components I hooks the (new) tweeters up to the door speakers also. It sounded OK, but I am pretty sure there is a crossover for those speakers. I can't remember if I ever did find the wires for the dash. The head unit connects directly to the dash or door speakers, I can't remember.
I went with a proper amp. I no longer use the dash speakers, I mounted the tweeters in the "A" piece on the door.
You will be doing a lot of wiring/spending too much time on an amp that results in a VERY muddy sound quality.
If he hooks it up the way I diagramed it will take maybe 15 minutes with only 4 wire splices and all the speakers will work just fine. It won't sound as perfectly clear as an aftermarket amp and new speakers but it will do just fine for him until he gets the money to replace and rewire everything.
I knew i had it hooked up right, turns out it was the fuse for the amp, it went bad, thanks fellas
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
