Oil Drain Pan Flange - Problem Solved
Tsibred1
139
Mar 5, 2004
New Berlin, Wisconsin
I had searched this subject for a while before and had only come across people either direct welding, expensive kits, or custom made flanges inorder to get a new flange/fitting on the pan to allow for a braided style oil drain. With some digging and a little bit of ordering for testing I've found a flange that is a direct bolt on. It's the Oil drain turbo flange for Garret GT series ball bearing turbos. Older style GT25s and T28s had this flange as well. Below are a few pictures showing the stock drain tube and the new flange side by side, if anything is needed, rubbing a drill on the inside edge of one bolt hole might be all it takes.
Nevermind no changes are needed to the flange, here are pics installed:
Good find, have a link to where you can get it?
I still prefer taking a non turbo pan and weling in a -10an weldable fitting. No chance for any leaky anywhere.
I would have prefered to do that, but after just cleaning RTV off the pan I was NOT ready to do it again. Atpturbo sells them for 15 bucks, otherwise there are alot of ATP vendors on ebay, I got mine from Himni Racing.
And yes, I will be putting sealant behind it for sure!
