what do i need to swap a 1.8 widda 2.0NT
SectorSe7en
Jun 3, 2002
im about to do an engine swap from a 1.8 to the 4G63, what do i need to replace? what can i keep? ex...tranny....intake manifold...ecu
You need a new intake manifold, exhaust manifold to fit a 4G63. You can keep your 1.8 transmission. As for the computer and wiring. I believe you need a new computer. As for the wiring harness i'm not completely sure. My Laser had a 1.8 in it and was replaced with a 4G63. There are plugs in the wiring harness that have nowhere to go. So I'm not sure on the wiring situation.
This was written to me by fast1.8sohcDSM. I had the same question and this is what he said:
To answer your 4G63T question, that is simple. ITS HARD AS HELL, LOL! THe transmission, for one, yeah its the same size, the fork is the same size too, but lets put it this way, you have a 5 BOLT flywheel, and it's defintely smaller, and you also have a small clutch set. SO that would all have to to replaced. Now if I were you, and I am not, I would make sure I have some good experience under my belt before I start thinking of doing a conversion. YOUR WIRING HARNESS IS TOTALLY DIFFERENT, your missing your coil pack wires, and the Cam/crank shaft positioner. Not to mention knock sensors and all that crap. So basically you would have to put a new wiring harness in from a turbo 1st gen, buy a turbo'd ECM, if it didn't come with injectors, you would have to get them. ANything it didn't come with you would get. THe only compatable thing you would have is your air filter. LoL, I know that sounds rediculous, but its the truth. A conversion of this mulitude, would cost... I would say around 2.5K.
2.5K?!?? plus professional installation?!? #@%#@%#@%#@% that...imma get that 1.8 of mine rebuilt
