Blueheat23
- 93
- Sep 8, 2003
Phoenix,
Arizona
Hey all,
New to the forum and just had a lil something to say.....
Since Hahn makes no stage kit for the 1G, i decided i was going to do my own turbo bolt on. In the end it was relatively cheap and im extremely happy with the performance....so i just thought id lay out what exactly i did to my NT as sort of a guide for all of you 1G NTers who might want to bolt a turbo on.....
First off i went to the junk yard....many valuble things there if you know what to look for....anyways i picked up a TSi Exhaust mani, downpipe, and the rest of the exhaust from the downpipe back....total cost at junkyard...150 bucks...i also bought a 1G o2 housing at the yard.....ok i stole the o2 housing at the yard. i could have taken off with everything becuase i had a buddys truck with a camper and the guy just let us go back and grab what we wanted then come up and pay for it...but i payed for all the other stuff...oh and i almost forgot, i went back about a week lata and bought the SMIC with both the upper and lower pipes and a TSi fuel pump for about 230 i think it was.
Next it was off to Ebay to search for a 14b....bought a used one for 120 bucks and it is in great shape..and it was a great deal...i also picked up some 450cc injectors.
So now ive got the turbo, the injectors, the full exhaust, the 02 housing, and the fuel pump....some of these things you dont even need to complete the bolt on setup, but i wasnt going to do my bolt on without them.....all of this cost me around 500 bucks.
I took it all to a local shop to have it installed because i wasnt confident enough to do it myself...
....all and all the shop charged me 650 bucks for labor to put everything in.
So now for right around 1200 hundred dollars i have a turboed NT.....i run 8 Psi daily but i wont ever take it any higher....plugs show absolutely no signs of detonation and i cant audibly hear any knock while driving the car....i always use premium though and octane booster every other tank.
With my high 9-1 compression ratio....8 psi should be putting me at right around 190-200hp or about a 50 percent increase and thats damn fine by me....damn fun to drive too
anyways just letting people know it doesnt take a whole lot to do the BOLT ON turbo (not the swap) mod and you get right around the same amount of power as a stock TSi because of the higher compression ratio...(a TSi without the turbo wouldnt have anywhere near 135 hp like the stock NT does because of the much lower compression ratio, power without the turbo would be much closer to 100hp which is why it takes less psi on the higher compression NT to equal that of a true TSi)
....all and all the shop charged me 650 bucks for labor to put everything in.So now for right around 1200 hundred dollars i have a turboed NT.....i run 8 Psi daily but i wont ever take it any higher....plugs show absolutely no signs of detonation and i cant audibly hear any knock while driving the car....i always use premium though and octane booster every other tank.
. but to answer your questions...
