tsi engine in esi talon
bboy
Jun 12, 2003
I own a 91 non turbo talon my engine was messed and I always wanted a turbo. I got a new engine put in only to find out it was a tsi engine, what they told me was it was rebuilt and will run is your esi but compression will be diffrent. so I have a tsi motor plus clutch, what I would like to know is
if I put a turbo in my talon with only a tsi eng and clutch what other upgrades will be needed to sustain the turbo? or will I need any at all?
need to know some info here......what came with the engine(head, flywheel, tranny, fuel rail, injectors, intake and exhaust manifolds.....)
i did the n/t to turbo swap last summer(swaped tranny, engine, exhaust, manifolds, wiring harnesses, everything.............so let me know what you have right now)
i sure as hell hope they swapped over all the correct parts, otherwise you just went from 9:1 compression down to 7.8:1 and the car will be a hell of alot slower.
