Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 420A DSM Tech > 420A Turbo Conversion
420A Turbo Conversion Turbo kits, swaps, etc - specific to 2G N/T DSMs.
Reply
LinkBack Thread Tools
Old 02-19-2003, 06:15 PM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: birdman is an unknown
block bore?
I was curious and I am doing my rebulind soon so I'm wondering why do people bore their block for oversized pistons .20, .40. what are the advantages/disadvantages to keeping stock bore or going.20 over? Would it be a wise choice to bore to .20 or would stock bore be just fine?could someone please help and explain this a little better to me. any advice is helpful. thanks
Offline
Related 420A Auctions
Sponsored Links
Old 02-19-2003, 06:27 PM   #2 (permalink)
DSMtuners N/T Wiseman
Reputation: 98Turbbo420A is an unknown
Going .020 over will give you a new starting ground to build on, personally I'm looking to go .030 to .040 (haven't decided yet) when I rebuild my motor. The only thing I suggest is make sure you know your machinest very well, and that you trust him, cause if the bore is off, ouch!
Offline
Old 02-21-2003, 09:18 PM   #3 (permalink)
Proven Member
Reputation: EklipseRS is an unknown
what gain from all this?
Quote:
Say I'm thinking of the following when rebuild mine too, any suggestion on power gain?
1_Top end crane cams kit (Street Performance Range Idle to 6500 RPM's Intake Duration 242@006 Lift .354 inch Exhaust Duration 242@.006 Lift .354 inch)
2_bottom end cams kit (Street Performance Range Idle to 6500 RPM's Intake Duration 242@006 Lift .354 inch Exhaust Duration 242@.006 Lift .354 inch)
3_.10 overbored pistons, probably 10.5 or 12.5?
4_port and polich head,
5_TB,
6_AFX pulley,
7_Lighten Flywheel,
8_exhaust, header, + my current Iceman
Offline
[posts] Reply With Quote
Old 02-21-2003, 09:34 PM   #4 (permalink)
Proven Member
Reputation: Turbo 420a is an unknown
Birdman,
Good luck with your rebuild. I'm probably going .020" or .030" over, you decide what size you want yet? If you're interested in a cheap place to find the parts:
http://www.howellautomotive.com
They offer their bottom-end kit for $1099.00. This comes with Eagle rods and JE Pistons and other various components you will need. If you have a source that offers the parts for less let me know, later.
____________________________
Evan
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.11508608 seconds (73.51% PHP - 26.49% MySQL) with 9 queries
