wookieneck
- 157
- Jan 27, 2003
Washington Court House,
Ohio
Researched this a lot and found nothing. Hopefully someone can save me......
When accelerating I am getting horrible hesitation, which I assumed was fuel cut. I had the missing link, so I took it off and put on the FCD. Same thing...
Running 4 psi it is somewhat noticeable, when I turn on the boost controller and run 7psi it bucks hard.
When it happens the A/F goes lean. Normal bounce, normal bounce, RED (big buck)
If I ease into the throttle it does not seem to be as bad, but when I nail the throttle it always bucks hard. The Fuel pressure gauge is consistent when the bucking occurs, in fact the only gauge that tells me anything is the AF.
In addition to changing out the ML for the FCD I have replaced the O2 sensor, the coil, the plugs, the plugwires, the injectors and the MaP sensor. Only thing I havent replaced is the computer and the TPS, oh and the cam sensor.
WTF?
WTF?
