Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 420A DSM Tech > 420A Drivetrain Tech
420A Drivetrain Tech Transmission, clutch, flywheel, driveshaft, gears, differentials, transfer case, shifter, etc - specific to 2G N/T DSMs.
Reply
LinkBack Thread Tools
Old 06-17-2006, 02:46 PM   #1 (permalink)
Proven Member
95TalonOwner's Avatar
Region: Midwest
Classifieds Rating: (0)
Reputation: 95TalonOwner is pretty helpful and trustworthy
96 Neon Tranny Q's
What is all needed in order to drop a tranny from a 96 neon into my talon? I'm just wondering.
Offline
Related 420A Auctions
Sponsored Links
Old 06-17-2006, 02:59 PM   #2 (permalink)
DSM N/T Moderator
VelocitąPaola's Avatar
Region: Southeast
Classifieds Rating: (5)
This should answer all of your questions...
http://www.2gnt.com/nuke/modules.php...icle&artid=142
____________________________
-Paul
Offline
Old 06-17-2006, 03:47 PM   #3 (permalink)
Proven Member
Region: Midwest
Thank you sir.
Offline
Old 06-25-2006, 12:34 AM   #4 (permalink)
Proven Member
Reputation: Morel is an unknown
I'm thinking about doing this as well.
Since the junkyard is filled with neons as far as the eye can see, but dang if I'll EVER see a 2g in it.. So, I want a manual from a Neon..
I've searched everywhere and I can't seem to find a list of what i'd need if it's even possible. I've foind lists about what i'll need if i'm swaping in a manual from another DSM, but not a neon..
God this cars getting me depressed. lol
Offline
Old 06-25-2006, 07:58 AM   #5 (permalink)
Proven Member
Region: Southeast
Classifieds Rating: (2)
Reputation: djXternal is an unknown
The link Paul posted should answer all your questions, I am also planning on doing this in the future, was going to do it this past month but the money and time just wasnt available
-Trae
Offline
Old 06-25-2006, 12:58 PM   #6 (permalink)
Proven Member
Quote:
That article assumes you have a tranny from a DSM avail.. ( I think)
What I wanna do is take the Manual tranny from a Neon and swap it into a Auto 2nd Gen..
Offline
Old 06-25-2006, 02:06 PM   #7 (permalink)
DSM N/T Moderator
Region: Southeast
The article assumes you already have a M/T tranny in your car. The bellhousings between our cars and Neons have different clutch actuation systems (cable vs. hydraulic), so you'd need to swap bellhousings to retain the hydraulic system.
Since you don't have an Eclipse M/T on hand, you could take most of the parts from the clutch assembly on the Neon and make yours a cable actuated system. You could also find a tranny from a 2001+ base model Neon; they have hydraulic clutches.
-Paul
Offline
Old 06-25-2006, 02:43 PM   #8 (permalink)
Proven Member
Nice! thanks a ton.
Now I wonder if I could use the linkage from the tranny to the shifter too..
Offline
Old 06-25-2006, 04:07 PM   #9 (permalink)
Proven Member
Region: Southeast
ok my bad didnt realize you were working with an auto
-Trae
Offline
Old 06-29-2006, 07:20 PM   #10 (permalink)
Proven Member
Region: Midwest
Classifieds Rating: (1)
Reputation: Talon ESI-T is extremely helpful and trustworthyTalon ESI-T is extremely helpful and trustworthyTalon ESI-T is extremely helpful and trustworthy
I see my writeup is getting used well...
Yes i wrote that assuming you have a MTX already.
Kepp in mind guys, the 3.55 trans is very slow if your not turbo. It was designed for a much lighter car. The idea of the 3.55 is to place more load on the motor to make an effort to reduce so much torque when your turbo spools. The intention is to install a 3.55 when you reach the 15psi marker. At 15psi I still spin in 3rd gear although i hook up faster than i did with my 3.94.
If you do not have a MTX car, you should look for a neon with a Hydraulic clutch. Then the trans will just swap over with the 2GNT brackets. Keep in mind the SRT-4 trans will not even fit in our cars. Nor will its quaife fit in our trannys.
Terry
MS powered 2.XL
Offline
Old 06-29-2006, 07:50 PM   #11 (permalink)
DSM N/T Moderator
Region: Southeast
Quote:
A damn shame that is, too.
-Paul
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.17732406 seconds (73.60% PHP - 26.40% MySQL) with 9 queries
