| 420A Bolt-on Tech Intake, exhaust, ignition, fuel system, cooling, etc - specific to 2G N/T DSMs. New Members must limit their 420A tech posts to this forum. |
12-22-2003, 12:47 PM
#1 (permalink)
New Member
Header for the 2.0???
What companies make headers for the 1G 2.0 N/T?
I know extrememotorsports has one.. but the details on it are vague whether its a 4-2-1 or simply a 4-1 design... and since there areno pics of it on the site I cant figure it out.
Anyone else have a header on their cars yet? And I absolutely refuse to run the pos pace setter header.
Offline
12-23-2003, 08:28 AM
#2 (permalink)
Proven Member
Region: Tri State
i got a header on my car and noticed a little bit of low end torque but not sugnificant hp.. i got mine from a junkyard i could ###### get you one if you want i think there is a pic in my gallary if you want to check it out....
Offline
12-23-2003, 10:58 AM
#3 (permalink)
Proven Member
i just checked your gallery and i found out that you have a turbo ecu, maf and injectors. isn't it too much fuel for your nt? any cams or other head work done ?
thanks
emiliano
Online
12-23-2003, 04:08 PM
#4 (permalink)
Proven Member
Region: Midwest
Hey, 91laserrsnt what did that header originally come off of? I got a pacesetter, no its not crap, ported/wrapped/sprayed, i like it
Offline
12-23-2003, 07:56 PM
#5 (permalink)
Proven Member
For the money you really can't go wrong with the Pacesetter Header. Buy it. Port it. Slap it on. You have a pretty decent flowing header. On the other hand, if you want stainless, go to machv.com they recently made the "Borla" Stainless header available for about $450... big bucks for the ultimate flow.
____________________________
I Laugh At V-TEC
Offline
12-23-2003, 08:12 PM
#6 (permalink)
Proven Member
Region: Midwest
I got my complete Pacesetter Exhaust from a guy on DSMTrader for $145 shipped  Only thing I dont like is the big ugly can thingy they call a muffler, and oh dont high temp paint your exhaust system, at least from the cat convertor forward it;'ll burn right off, I did it as rust prevention, and seems to be holding up well from cat back, and if your wrapping a header use some of this special silicone spray to prevent your wrap from absorbing water and rusting out the pipes good luck on your choice, cheaper is better fo me im an EBAy shopper
Offline
12-24-2003, 04:26 AM
#7 (permalink)
Proven Member
Region: Pacific Northwest
i like my pacesetter, just dont use the collector that comes with it...
Offline
12-24-2003, 07:43 AM
#8 (permalink)
Proven Member
Region: Midwest
what do you mean collector below ambient?
Offline
12-24-2003, 09:12 AM
#9 (permalink)
Proven Member
Region: SoCal
Is it better to install your own headers, or the the muffler shop do it.. I just bought a pair of pacesetters for my car and it cost me $240 from the shop and $40 install. will have them put in day after X-mas..
Offline
12-24-2003, 11:15 AM
#10 (permalink)
Proven Member
Region: Midwest
its pretty easy to install, you gotta remove the power steering pump to get the header on/off, then unbolt the dp and your set expect about an hour and a half of time, spray the crap put of the rusty exhaust manifold bolts on the head with some rust breaker something like liquid wrench, before do this days in advance so you dont break a stuf or 2 or 3 lol
Offline
12-25-2003, 08:20 PM
#11 (permalink)
Proven Member
Region: SoCal
how much Horsepower do you gain by adding these pacesetters?
Offline
12-25-2003, 09:21 PM
#12 (permalink)
Proven Member
Region: Tri State
Quote:
it came off of a hyundai 1.8 dohc not sure what model but it works good not as pretty as some of the othere 150 to 250 dollar ones out there but alot cheaper i only spent 20 bux on this from a junk yard and all i had to do is to but the o2 sensor in it with a bung nut about 5 dollars...
Offline
12-25-2003, 09:23 PM
#13 (permalink)
Proven Member
Region: Tri State
Quote:
thanks
emiliano
no its not to much works good gives me slightly more power and it pulls lower in the rpm range now..plus if i ever what to go turbo i dont need much to do it...and i do have some head work done not to crazy just ported it myself one day and i am running stock cams but plan to get the turbo cams or some other more aggressive cams...
Offline
12-26-2003, 02:02 AM
#14 (permalink)
Proven Member
the collector is the pipe that connects your header to the cat... that part is crap and has so far broken twice... i have yet to have any problem with the header itself...
Offline
12-26-2003, 05:34 AM
#15 (permalink)
Proven Member
Region: SoCal
Quote:
at which point did the collector break? I was thinking about adding the whole pacestetter, header-and collector. its all crome and looks performance..whats best for the car?
Offline
12-26-2003, 11:54 AM
#16 (permalink)
Proven Member
it broke twice on the flange that connects the collector to the header itself... very cheap metal imo...
Offline
12-26-2003, 03:43 PM
#17 (permalink)
Proven Member
Region: Midwest
Im gonna have that pivot ball section cut out, and have a flex section welded in.
Offline
12-29-2003, 09:58 PM
#18 (permalink)
Proven Member
Region: SoCal
Just had my pacesetters put in. and my car runs great. way better pick up and redlineing. the whole header was put in w/ collector but welded to the cat. My car now sounds more racey and smooth...
Offline
12-30-2003, 05:22 PM
#19 (permalink)
Proven Member
Quote:
can't beleive anyone would pay to have a header put in their car... sure if it were a small block Mopar A body sicne you haev to take off half the suspension, but it was was easier to install mine than it was to install my air intake...
i would take the car back and have them install a different collector.. that collector is junk...
Offline
12-30-2003, 09:03 PM
#20 (permalink)
Proven Member
Region: SoCal
what collector should i use? or can I just remove it and weld in a straight pipe...
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
