which turbo
Stock_Eclipse
Nov 4, 2003
I am looking to put a turbo on my non-turbo and I wasnt sure what would be the best one for my 420a? My plan is to rebuild another motor and drop the compression so I can run higher boost. So if anyone has any ideas please let me know I would greatly appreciate it.
Kyle
Originally posted by TalonESi
Super 16G, but really it depends on how much boost you plan to run.
I plan to run at least 16 psi through it just drivin and then go from there when I race or am at the track
There are other things to worry about besides the size of the turbo that you wanna run. If you get the HRC turbo kit it comes with the S16G standard. From there you can go up to the 20G and soon the 25G with accompanying mods..
If you get the Star Performance kit it comes with a T3/T4 and from there you can get the E-trim with the ball-bearing center section.
If you plan on running anything like 16 psi then you will NEED to get forged internals and a fuel system that can handle that much boost. Otherwise you can kiss the motor goodbye. Go to 2GNT.com and read up. All the helpful info you can ever want for your car.
Good luck!
  • Wanted 2g ABS - Left side harness brackets
    Looking for the metal brackets for left side ABS wiring harness. Sensors not needed
    • Justin DuBois
  • For sale 2g 2GB CAS Assembly ( Complete )
    2GB CAS Assembly ( Complete ) $85 + shipping and paypal feesYou must be registered to see element.
  • For sale 2g 2G Clock Spring, Wiper Stalk, Turn Signal Stalk
    2G Clock Spring, Wiper Stalk, Turn Signal Stalk $35 + shipping and paypal fees* removed from...
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
