Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > General > Newbie Forum
Newbie Forum Beginner/newbie/general DSM questions. first mods, how to run 10's when you haven't run 12's yet, any tech question that doesn't fit in another tech forum. New Members must limit their tech posts to this section.
Reply
LinkBack Thread Tools
Old 04-26-2003, 04:39 PM   #1 (permalink)
Proven Member
Sinner's Avatar
Region: Tri State
Classifieds Rating: (0)
Reputation: Sinner is more helpful than not
Crank Scraper crankshaft scraper [Merged 12-6]
I was wodering if anyone has used one on the 420A. I found one on ebay http://cgi.ebay.com/ebaymotors/ws/eB...category=6770. From my past expirence with V8's I know they are a good thing to used and gain some people 10-15 horse on a V8, but I have yet to hear anything about them for a four cylinder motor. I plan on replacing my rod bearing cause they went bad and I was wodering if this might be worth my money to put in while I'm there.
____________________________
Jeremy
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Old 04-26-2003, 11:30 PM   #2 (permalink)
Proven Member
Reputation: siueclipse is more helpful than not
i bought one.. i felt a slight differece.. also.. i created their website.. www.crank-scrapers.com
nothing much cause they didn't want to pay much
Offline
Old 04-28-2003, 08:07 AM   #3 (permalink)
Proven Member
Reputation: supergoat is an unknown
Crank scrapers are a good/cheap mod.
Stephen Wilds
Offline
Old 05-16-2003, 07:40 AM   #4 (permalink)
Proven Member
Reputation: burstspeed96 is an unknown
Crank scraper
Any body using crank scrapers? It this gasket style thing that scrapes oil off your crank. Its suposed to help engine longevity and improve power. Could this possibly be a crank walk fixer?
Offline
Old 05-17-2003, 03:30 AM   #5 (permalink)
Moderator
Defiant's Avatar
Classifieds Rating: (1)
Hm. Not likely, it's mostly intended to keep the crank from windmilling your oil, and get it off the outside of the crank and big ends. I can't see how it would have any effect of crankwalk.
Offline
Old 05-17-2003, 05:41 PM   #6 (permalink)
Proven Member
Reputation: blue1 is pretty helpful and trustworthy
Crank scrapers are good if you take the time to make them up. Crank walk comes from three causes that i know of: block not line bored correctly, clutch apply pressure way to big!, and believe it or not your earth straps from battery to body and engine to body missing or damaged! Causes arcing on the sides of the main bearings when you have a great current draw and the battery is looking for the best earth to supply the other side of the 12Volts.
Offline
Old 10-29-2003, 04:05 PM   #7 (permalink)
Proven Member
Region: Southeast
Reputation: interceptor is an unknown
Crank Scraper
Does any one have it and is it worth getting .
http://www.crank-scrapers.com/products/mitsu.html
Offline
Old 10-29-2003, 04:06 PM   #8 (permalink)
Proven Member
Reputation: 97eclipseRS is more helpful than not
what does it do
Offline
Old 10-29-2003, 04:13 PM   #9 (permalink)
Proven Member
Region: Southeast
http://www.crank-scrapers.com/index.html
READ !!!
Offline
Old 10-29-2003, 04:15 PM   #10 (permalink)
Proven Member
haha damnit i just got owned like a noob sounds like a good buy, let me know how it is before i drop the 50 bux
Offline
Old 10-29-2003, 04:20 PM   #11 (permalink)
Proven Member
Region: Southeast
Will Do
any one else
Offline
Old 10-29-2003, 06:45 PM   #12 (permalink)
Proven Member
Reputation: Blueheat23 is an unknown
I dont know about u but just the name scares me....I dont want ANYTHING, scraping my crank. I noticed on there they make one for the 4G37 1.8L, then it says they make one for the 1G 4G63 SOHC engine....there isn't a 4G63 SOHC, that would be the 1.8 4G37. Sorry I'm nit-picky like that.. Interesting concept though, go for it and see what it does...I doubt it would really help performance much, but it's worth a shot.
» Signature edited due to sig policy violation
Offline
Old 10-29-2003, 10:05 PM   #13 (permalink)
Proven Member
Reputation: silvereclipse is an unknown
A lot of people are just finding out about these, they have been used in race v8s for a long time with impressive gains. I have heard a few DSM people say they could feel a difference, plus it makes things easier on your engine. BTW the ends of your rods don't actually scrape the piece but come very close. This is to prevent oil from weighing down the rotating peices, less power wasted slinging around oil. I will probably get one for my next oil change.
Offline
Old 10-30-2003, 03:13 AM   #14 (permalink)
Moderator
Defiant's Avatar
Quote:
Originally posted by 97eclipseRS
what does it do
It's an odd-shaped piece of sheet metal cut to _almost_ touch the crank and rods on the "coasting" side of the assembly, and it wipes most of the oil from the rotating bottom end. This cuts down on windage and oil whipping, and has a very slight effect of reducing rotating mass. There are stories of V-8 research engines with windows and monitors sailing golf-ball sized clumps of oil around in the crankcase when wound up- there's a helluva wind going on inside there with those big ends whizzing around at a bazillion miles an hour. Once you've gotten every last tenth of a horsepower out of a motor, you have to look for the last lurking strays from the herd.
Of course, you also have to be aware the trail's well-salted with horseshit.
Offline
Old 10-30-2003, 06:23 AM   #15 (permalink)
Proven Member
Reputation: rookieupgrade1 is an unknown
Quote:
LMAO
If you have your engine maxed out in its potential power you MAY have a minimal gain with one. I'd save my $ and buy a part that makes a diffeance and has less theory to its HP gain.
Gary
Offline
Old 06-25-2004, 11:29 PM   #16 (permalink)
Proven Member
Region: Southeast
Reputation: Kevin Johnson is an unknown
Crank scraper
SOHC 4G63 came in the 89-92 Galant. I pulled a motor myself to check it out and compare it to the G63B and 4G63t 1g of the same vintage.
A retired Chrysler engineer who worked on the 2.2 Shelby Charger engines reported that Chrysler and Mobil did joint research back in the mid 1980s on windage losses for that engine. (This is the gentleman who made aftermarket racing oil pans for several years for the Shelby racers -- no, he said that he does not want to get back into that -- I asked).
They picked up 7 hp at 6000 rpm and 9 hp with Mobil-1 using a crank scraper type windage tray. It is difficult to get this kind of info because it is circulated within the car companies but not available to the general public.
Hope that info helps!
Kind regards,
Kevin Johnson
Ishihara-Johnson Crank Scrapers
Offline
Old 06-26-2004, 10:04 AM   #17 (permalink)
Proven Member
Reputation: Daedalus is an unknown
A lot of the honda guys that are all-motor here in omaha run them and swear by them. If your gonna take off the oil pan might as well get some hp for your efforts. A+ to crank scrapers!
Offline
Old 06-26-2004, 10:20 AM   #18 (permalink)
Proven Member
Reputation: DongeR is an unknown
I’ve heard crank scrapers before and...
How close are they supposed to be to the crank? I heard a car making more audible noise with it on. Is that normal?
Offline
Old 06-26-2004, 12:43 PM   #19 (permalink)
Proven Member
Most likely the noises werent from the crank scraper. It comes close to the crank, but doesnt touch it, therefore it should be silent. The noise was probably something else, and if it was from the scraper, its not installed correctly and should be checked.
Offline
Old 06-26-2004, 09:36 PM   #20 (permalink)
Proven Member
Region: Southeast
Thanx Kevin Johnson for the crank scraper.
Offline
Old 06-27-2004, 09:37 AM   #21 (permalink)
Proven Member
SnoopySLR's Avatar
Reputation: SnoopySLR is more helpful than not
I don't know if I want metal that close to my crank. Does anyone have one of these? I need to drop my oil pan soon cause my gasket has a leek. Just wondering if its safe. Last thing I need is the thing to move and start scrapping against my crank.
-John
Offline
Old 06-29-2004, 03:53 PM   #22 (permalink)
Proven Member
Region: Southeast
Reputation: JWoodley is more helpful than not
tried and trusted...
Offline
