powells85
- 267
- Nov 9, 2002
Hey guys, I was trying to install the AFX UDP and i cut the old belts off and took off the motor mount and dropped the engine and took the bolt out of the crank pulley. Then I took the 5 ton 3 tooth gear puller and started trying to take off the stock pulley but it won't budge an inch. I was working on it for 7 hours today and it did not even move at all. Did anyone else encounter anything like this, if so what did you do? Also, could I just wedge something in the pulley and against the sub-frame and crank the motor over to get it to break free or is the pulley seated in the crank somehow? Please guys I need help. Thanks a lot.
