420A compression check results...help
Eagle 5
380
3
Jan 26, 2003
Cincinnati, Ohio
Did a compression check on my car few minutes ago and here is what i came up with. did this since i bought a turbo for it and also i have a oil consumption problem. this is on the 420A engine
Cylinder 1 = 210 spark plug was fine
Cylinder 2 = 180 spark plug was fine
Cylinder 3 = 210 spark plug had oil on it
Cylinder 4 = 210 spark plug was fine
Added a cap full of oil to cylinder 2 and let sit for a minute then redid compression check on it...twice
Cylinder 2 2nd time 300 !!!!
Cylinder 2 3rd time 270 !!!!
My conclusions and the guy who helped are that cylinder 3 has bad valve seals and that is why oil is on it. Also i replaced the PCV valve and found oil in the tube and the valve
Cylinder 2 piston rings must be going out if the compression jumped that much, or something else happened or is happening.
SO what does anyone have to add or what not?
Originally posted by 3L3C7R0
I know this is totally off topic, but I love your sig pic man, fro mthat angle it almost looks like a supra, you have one bad ass looking car.
Thanks man! never heard of it looking like a supra but still cool. thanks again.
on topic, i have heard it could be spark plug seals on the valve cover or stem seals that is letting oil on the plug. and i also heard that having one cylinder 20 or so less was normal wear. im going to get a leakdown test just to be sure but heck, my engine might be in great shape for having 117,000 miles on it.
Check these engines out
Yeah i have seen those. If my engine ends up having a piston ring problem then i will msot likely end up getting that engine. unless i find someone around my area who can do the same work and have it done cheaper (actually might know 1 person, but not sure yet) ill probably get one of those....be perfect for the turbo kit that is coming soon
I have or had the same problem I was changing my spark plugs and I put my socket wrench down and removed my spark plugs and oil was dripping off of the spark plug and was all over the socket...I took a fashlight and saw a small pool of oil in 2,3 and 4th cylinders were my spark plugs go...finally I figured it out...valve cover gasket is leaking from the inside(spark plug seals) I belive because when I went to order a new gasket...they mentioned that spark plug seals could be the cause of the leak so I ordered the spark plug seals and the gasket...Its getting replaced soon next week along with my timing belt and new valves...
