sike
- 59
- Dec 18, 2001
Baltimore,
Maryland
Just completed the swap and it runs good, but I have a few wiring problems that I can't figure out. For one, the neutral saftey switch, I located it on the trans, pulled it off and put it on the connector from the ECUs and I have it wedged in there so its grounded to a bolt and pressed down so I can start the car. How do I connect the clutch pedal so the car will not start when the clutch is not engaged. The neutral saftey switch wiring is 3 wires I also don't know how to bypass the wiring rather than wedging the switch in there. Also I can't get they key to come out, even when the neutral saftey swtich is in, its getting annoying having to take my radio face off everytime I get out of the car. Any input is appreciated.
