95gsttsi
- 132
- 1
- Aug 20, 2010
Sturgis,
Michigan
So I recently did a stock floating head swap with a freshly built head and pulled 390cc injectors from my old head well one of the black plastic pieces broke off tue bottom of one and at this point all I have is a stock set and a set of 680cc injectors.. I am running a walbro 255 an aftermarket fpr and a fmu wity fuel cut.. on the 390's I was pushing 20psi no problem. My fpr is set at 43 psi at idle. And ranges between 43-60psi under a load... what I'm getting at here is with my fpr set the same will the 680's dump too much fuel? And is tyere anything I can do to compensate?
