Cat or Straight Pipe
MY_Game
123
May 8, 2002
Can someone help me out? Which is better for a non-turbo a high flo cat or a straight pipe? Thanks...
But the actual backpressure that is good for engine, to suck the exhaust out is acustical, and just having a restrictive device (assume the cat's contents acts like a restrictive air filter in the line of the exhaust) would just cause build up, as say a resonated testpipe, which reflects low pressure waves back up the headers which "grab" the exhaust and "pull it out". There is a link to a good explanation on how "backpressure" works somewhere in this forum. I'll post it when I get to my computer at home. So, I think that a resonated testpipe would work the best out of a straight testpipe, resonated testpipe, or high-flow cat. You can get one from www.testpipes.com, it will also make your exhaust note quiter, deeper and manlier sounding.
  • Wanted 2g ABS - Left side harness brackets
    Looking for the metal brackets for left side ABS wiring harness. Sensors not needed
    • Justin DuBois
  • For sale 2g 2GB CAS Assembly ( Complete )
    2GB CAS Assembly ( Complete ) $85 + shipping and paypal feesYou must be registered to see element.
  • For sale 2g 2G Clock Spring, Wiper Stalk, Turn Signal Stalk
    2G Clock Spring, Wiper Stalk, Turn Signal Stalk $35 + shipping and paypal fees* removed from...
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
