data log numbers bad?
litlred515
Sep 5, 2003
ok so i just went for a little run and logged it. my numbers i defiently dont think are good.
rpm 6727
o2v .95
timing 43
tps 75
short trim 24
longtrim 12
mph 101
map 29
load 90
what i'm getting from that is that my timing is way off and i'm defiently running way rich. i was running nitrous during the run so could that play a major factor? even with that i still think something is wrong. let me know what you guys think, any input is helpful
rpm 6727
o2v .95
timing 43
tps 75
short trim 24
longtrim 12
mph 101
map 29
load 90
TPS Isn't at 100% so it's going to be a little difficult to tell you for certain if these numbers are the ones we need to be looking at for aiding you tune the car.
I logged my neon and here's a comparison for you. Neon and 2gnt are comperable since they're both chrysler 2.0Ls and have SBEC controllers. So just pretend that it's a fellow 2gnt.
Start of 1st gear pull:
RPM 945
o2 0.02
timing 16325 adv
TPS 0.00%
MPH 3.29
MAP 13.06 iHg
Mid pull:
RPM 2761
o2 .89v
timing 31.60 Adv
TPS 99.98%
MPH 13.29
MAP 29.29 iHg
Top of pull:
RPM 5443
o2 .91v
Timing 33.00 adv
TPS 99.98%
MPH 26.41
MAP 28.91iHg
This was right before a shift in to 2nd. Most people compare 3rd or 4th gear pulls but what I wanted to point out was high TPS/RPM/o2/timing advance. So I would recomend showing us some pulls when you're at 100% for a good time.
Doug
Can I Have my tracking Number on the datalogger i bought from you litlred515? Its been 8 or 9 days and i havent gotten it yet.
