XECLIPZEX
- 113
- Aug 19, 2002
Cullman,
Alabama
I know this might not work but I want to try it anywayz. Is it possible to get a smaller serpintine belt and run it a certain way where it would not be running the a/c pulley or the power steering pulley. Also is the water pump or anything important located on one of these pulleys. If so wich one is it. I figured if you could do this it would be a good way to get hp and if you wanted power steering or a/c all you would have to do is put the stock belt back on.
