1995 Eclipse's with S-AFC please come in and help...
a5ian5murf
155
Oct 8, 2002
Bay Area,
What's up guys, yeah im in need of help with my S-AFC... I've done search's for month's now, trying ALL of the diagrams used. I don't even want to look at another one anymore, because i literally looked at every single wire hooked up to the ecu (disconnected it).
Now i want help from only actual people that have it on their 95 cars. I need to find the WHITE solid wire for the RPM signal. The reason i need this so much at the moment is because at night, none of my tachs light up, i dont feel like paying a technician at a shop to fix it, and also i don't really want reverse indiglows or anything like that. I have this safc that will do the job, but i need help with it. Please only 95's with experience. And no diagrams, actual people that installed it, i need help from you, actual pictures can also help. Thanks guys!
it should be a white wire... for the tach signal... hold on let me go check my car LOL
wow its cold out here in jersey LOL
KK BACK.... bottem clip.... Solid wire wire ... mostly all of the wires have colors with a stripe.... the rpm signal has no stripe its just straight white...
Actually nevermind,
i havea 1998 eclispe
1997-99 have obd2 computers so they have 2 clips
and 95-96 have obd1.... so there is only 1 clip...so im totally wrong i think
Buy a haynes manual if you don't allready own one, you should find what wire it is and how to get to it in there.
I talked to my Brother , he has a 95 gs and he said it's still a solid white wire, but he conected at the dash cluster and it is the only solid white wire , hope this helps .:hellyeah:
