for you who have a UDP and cam gears
lovemycar11
30
Apr 7, 2003
Salem,
When putting new cam gears in and installing an underdrive pulley, what size timing belt do you use.....or do you use the stack size?
timing belt????
Uh...I dont think the timing belt has anything to do with the udp, not sure about the cam gears tho. Go to a mitsubishi dealership, bring the cam gears, and have them pull out an OEM belt and see if the belt fits snug over the cam gears.
The OEM belt will fit on the cam gears. If its the original, might want to swap that out also.
DO NOT take it to the dealership, unless you want to get ripped on the charges.
Take it to a reputable shop.
Install instrustions for UDP:
http://seangordon1.tripod.com/UDPinstall.html
Please search next time, the link I provided was found 1-2 threads down.
UDP you need accessory belts, not timing belts. Cam gears, you need to loosen the belt then retighten it accordingly to your new gears.
